Other Parts Discussed in Thread: BQ25170
Hi
The customer design with LM3658, when the temperature reaches a certain value, the voltage of TS exceeds the threshold range, and the LM3658 turns off the charging process. At this time, due to the heavy load turning into no load, the voltage of the TS rises by about 40mv, and falls into the threshold range again.
The LM3658 turns on the charging process. In the process, the TS voltage is pulled down again, and then charging is turned off... This repeats, causing the charging IC to repeatedly turn on and off charging within a certain temperature range. Is there any way to improve the TS voltage fluctuation?
The schematic as below:
Please help check it.
Star
