TPS6521905: function to adjust the output voltage rise time
Part Number: TPS6521905
Is it correct that the TPS6521905 does not have the Soft Start output voltage of the Buck1~ 3? Could you tell me if there is a function to adjust the Slew Rate?
Also regarding LDO1~3, I understand that Ramp Up Slew Rate fast/slow is a function to adjust the output voltage rise time. Is this correct?
Nishie
