Other Parts Discussed in Thread: LM5170,
I already follow another forum,
Also I set under the picture, by LM5170-EVM 2EA (Already Solder a copper strip on the back side)
An experiment was conducted to check the converter output in buck mode through analog control.
If the Power(Output) is 1.3 kW or higher, the Conveter will go down.
Goal is 2.0kW output.
How can I solve that.
Thank you.
