Hi team,
1. Is it set based on the lowest voltage of the LED light string?
2. The FB resistor has two modes: 2-resistor voltage division and 3-resistance voltage division. Based on previous experience, it is recommended to use 3-resistance voltage division when R1 (FB upper side resistor) is less than 200k.
Want to know the reason for this suggestion?
3. When using three resistors to divide the voltage, are there any requirements for the resistance range of the three resistors?
