1. FAE told me when I connect VO with OUT, the device will lose the function of load disconnect at shutdown and output short protection.
I execute the simulation(connect VO with OUT).It is found that before 2ms, there would be a turning point in the waveform. Is this normal? Will there be another adverse effects?
2. I don’t quite understand the function of the PG pin and how to design the resistor value.(EVM board PG pin element is 100k ohm)
Can it be floating?
Thank you.
Best Regards
Yufang
