BQ76952EVM: BQ7695203
Part Number: BQ76952EVM
Other Parts Discussed in Thread: BQ34Z100
Hi Sunna,
I want to use Read PassQ register and updating performance parameter like SOC, Charge/Discharge Ah. but  sometimes i have observe that SOC decreasing very fastly
(1) Whenever Current Direction is changed  send the command to Reset the PASSQ register
(2) Then Compare the value with PreAccumulated charge value and Adding the delta Ah to Charge /Discharge Ah.
//============================================================SOC Decrement when BAttery is discharging
if(s_BMU_Data.AccumCharge.Value<s_BMU_Data.prev_DischargeAccumCharge10mAh.Value) //s_BMU_Data.AccumCharge.Value reading from BQ PassQ Register
DeltaAh=(s_BMU_Data.prev_DischargeAccumCharge10mAh.Value-s_BMU_Data.AccumCharge.Value);
s_BMU_Data.DischargeBQmAh.Value+=DeltaAh;
s_BMU_Data.prev_DischargeAccumCharge10mAh.Value=s_BMU_Data.AccumCharge.Value;
s_BMU_Data.DischargeBQmAhSOC.Value+=DeltaAh;
if(s_BMU_Data.DischargeBQmAh.Value>=10)//with 1 decimal,100mAh
temp=s_BMU_Data.DischargeBQmAh.Value/10;
st_SysPerf.para.DischargeAh+=temp;
st_SysPerf.para.curDischargeAh+=temp;
s_BMU_Data.DischargeBQmAh.Value=s_BMU_Data.DischargeBQmAh.Value-(temp*10);
st_SysPerf.para.currentDischAh=st_SysPerf.para.currentDischAh+temp;
pageUpdateFlag=1;
if (SOC>=s_BMU_Data.DischargeBQmAhSOC.Value)
SOC=SOC-s_BMU_Data.DischargeBQmAhSOC.Value;
Can you share any algorithm for measurement of SOC etc.
