Part Number: TPS82084
Section 7.3.3 of the datasheet for TPS82084 indicates that the device has a typical VOUT soft startup time of 0.8 msec. Is the soft startup time temperature dependent? For example, is the time longer or shorter at lower or higher operating temperatures? If so, can you provide any data on soft startup time temperature dependence? Also, if 0.8 msec is the typical soft startup time, can you provide minimum and maximum times?
