benefit of Vbias for LDO, TPS74801
 what is the benefit of Vbias pin of LDO? understand it can improve Efficiency but anybody can elaborate on how to improve efficiency?
  • Vbias provides the gate drive for the regulator's n-channel FET.  As opposed to a regulator with a p-channel FET, the n-channel FET has lower Rdson for the same die area and current rating.  Therefore, a lower voltage can be applied to the regulator's power input (VIN) as compared to a similar current rated, p-channel FET regulator.  Since regulator efficiency is Vout/Vin, the regulator with Vbias will be typically be more efficient than a PFET regulator.
