LM27762: LTSpice error when generating negative voltage
Part Number: LM27762
Other Parts Discussed in Thread: PSPICE-FOR-TI
My goal is to generate +3V and -3V using this component. However when EN- is high (negative voltage active), the simulation fails and errors out after a bit. PGOOD is also high when it should be 0V. As far as I can tell, the capacitor values and resistor values I have chosen are correct as per the datasheet.
Any help is very much appreciated.
