Other Parts Discussed in Thread: , EV2400,
I am developing a driver for BZ27Z561 and I am trying to get interrupts when the RSOC changes. According to sluubo7, I should just set "INT_EN" in "IO Config" and "SOC delta" to a non-0 value. I do both of those things (I"NT_EN" is 1, "SOC delta" is set to 1), but I never get an interrupt, even though RSOC does change (which I verified by reading RelativeStateOfCharge()) At this point, I should explain that I had an issue while trying to read and write the data flash on the IC, the issue can be seen in https://e2e.ti.com/support/power-management-group/power-management/f/power-management-forum/1310382/bq27z561-issue-with-reading-data-flash/4981582. Long story short, I am working with a flash map that is not described in any datasheet that I am aware of (the data flash offsets in sluubo7 do not apply to the particular firmware version on my IC). Furthermore, in this flash map, the "IO Config" location in data flash is shown to have this structure:
