Hello Team,
I found that a problem about use the TPS92682+TPS92520,TPS92682 is set consant voltage 50V,TPS92520 constant current is set 1.3A,when I change the output voltage from 4~40V,
the output current will occur change too,
Could you explain to me which factor will influence the output current accuracy?
I found that other user have the same problem too,and you send a E-mail to him,could you share with me?
e2e.ti.com/.../tps92520-q1-could-you-provide-the-tolerance-of-v-csp-csn-with-4-sigma-limit
