hi Sir
I want to design a 1kw power, use the UCC28019A, I use the NTC to Limit the inrush
now ,I need to Add a Relay,in parallel of the NTC, did you have any advise ?
the ic have any pin to control the Relay?
hi Sir
Hello Alex1,
Thank you for your interest in the UCC28019A PFC controller.
This controller does not have a pin or signal to control a relay to bypass the NTC resistor.
You can add an external control to turn on the relay after a time delay, or after the PFC output voltage exceeds some level, or based on some other criterion, or a combination of all three.
The relay and its control circuit will need a power source that is active at (or very shortly after) the time of inrush.
Ulrich
