Hi team,
As D/S says, the recommendation range is between 100pF and 100nF.
But when we talked with BU, they said the 100nF capacitor with ±10% tolerance should be okay. This means 110nF should be okay.
Do you have any specific limitation for this caps? If yes, what is the reason? In my understanding, there is no theoretical limitation and user can put large caps to delay the time as much as they want. Is my understanding correct?
Shoji
