TPS568230: Questions of TPS568230
Part Number: TPS568230
Other Parts Discussed in Thread: TPS548A28, TPS56C230, TPS56C215, TPS56C231
Dear Team,
Do we have suitable solution can replace MP8774?
Many Thanks,
Jimmy
  • Hi Jimmy
    1. TPS548A28 is DCAP3 with selectable frequency in 4mmx3mm package with Hiccup for OC and UV faults, latch-off for OV Fault
    2. TPS56C230 is DCAP-3 with 500kHz frequency in 3mmx3mm package with Hiccup for OC and UV faults and Non-latched over-voltage, under-voltage, overtemperature and under voltage lock-out protections
    3. TPS56C215 and TPS56C231 is DCAP-3 with selectable frequency in 3.5x3.5 mm package
    and may I know what is the application required Vin and Vout range and what type of fault protections are needed
    Thank you
    Savith
