BQ25708: BQ25708 charger together with host and smart battery on same bus
Part Number: BQ25708
Hi!
The Smart Battery Data Specification is talking about charger, host and smart battery communicating with each other on the same SMBus (http://sbs-forum.org/specs/sbdat110.pdf).
Would the BQ25708 support to be on the same bus with both a host and a smart battery at the same time?
Edit: I am asking because the datasheet does not explicitly show this in the application diagram and states that the SMBus is to connect to a host OR Smart Battery. In contrast, the application diagram from e.g. https://www.analog.com/media/en/technical-documentation/data-sheets/1759fs.pdf shows this connection explicitly.
