Part Number: TPS552882-Q1
Other Parts Discussed in Thread: TPS55288-Q1
I have a question regarding output load discharge configuration for TPS55288-Q1
The datasheet state that output fast discharge through internal constant current will turn on when OE is clear and dischg bit set. I have verified that this scenario is working. I like to check if setting the dischr bit when OE is high is valid as I see that setting this bit while reducing the output power profile does not change the ramp down time.
Best Regards
Martin
