Other Parts Discussed in Thread: TPS55289, TPS65987, USB2ANY
Dear SIrs and Madams,
We would like to consult about how to control TPS55289(SW- Reg) from TPS65987(USB PD) using I2C.
I think it is necessary to control the switching regulator in order to supply 5V/3A to the monitor and perform DP output of ALT MODE.
(1)
When evaluating, is it possible to control and set the switching regulator from the PD controller (TPS65987) side using the application GUI (TPS6598X-CONFIG)?
(2)
Or should I use USB2ANY to configure the I2C settings for TPS55289 from the PC GUI (TPS55289EVM)?
If both (1) and (2) are possible, which one would you recommend for operation verification?
MM
