TPSI3050-Q1: Enable switching frequency in Calculator
Part Number: TPSI3050-Q1
Other Parts Discussed in Thread: TPSI3050
I'm using TPSI3050 to control a pre-charge FET that will be ON during normal operations, as in the FET gate will not be switching frequently.
For the calculator, what should I put in as the Enable switching frequency?
  • Hello Mable,
    Thanks for reaching out to our team on E2E and taking a look at our calculator tool. Since it is only turning on once, you can just leave the EN switching frequency field blank and confirm that the settings are otherwise correct.
    Tilden Chen
    Solid State Relays | Applications Engineer
