Other Parts Discussed in Thread: LMR38010
I was wondering:
what is the behaviour of LM5163 and LMR38010 SW pin when some current is injected on Vout (from 0mA up to 50mA), with Vout=0
i.e. when Vout rail is pulled up by an external mechanism (such as a protection diode+pullup resistor).
NOTE: the behaviour herein described is inherent to protection devices only, meaning not a proper voltage regulator placed in parallel to LM5163/LMR38010.
Some pullup current may enter SW pin under these two separate conditions:
1) when Vin > Vin_min but Ven < enable_threshold
2) when Vin < Vin_min (e.g. Vin=0) and (of course) Ven < enable_threshold
Note: FB pin would be powered as well, but through an equivalent high impedance resistor (>10KOhm)
I assume current would be injected backwards to Vin through High Side MOS intrinsic diode,
or is HS a proper hardware switch (e.g. two n-MOSes with common source), and hence Vout is floating when regulator isn't enabled ?
If currents is injected backwards to Vin,
are the related parameters of the HS MOS fully specified ? (i.e. intrinsic diode parameters, and in particular diode continuous / pulse forward current)
Would this current damage Vds comparators (LM5163/LMR38010) or Zero-crossing comparator (LM5163)?
Thank you very much in advance
Alex
