UCC21520: UCC21520 control
Part Number: UCC21520
I want use the UCC21520 to control the marx curcuits, UCC21520 will be used to control the IGBT(1.2KV), so:
1. If the switch voltage is 750V, is the UCC21520 work voltage is suit to control the IGBT?
2. UCC21520 has two channel, is it can be worked independently, I means the two channel both worked on high side or low side or mixed(half bridge), depend on my choice. And th control signal INA/INB can be a constant signal(100%  high voltage or 0v)?
  • Hi Tianlin,
    Thank you for your interest in our device!
    Answering your questions:
    1.) Yes, the UCC21520 is rated to sufficiently control a 750V switch.
    2.) Correct, the two channels are independent and can be used to drive a half-bridge or both low side / high side. The inputs can also be a constant high or low as well.
    Hope this answers your questions.
    Hiroki
