Part Number: TPS48111Q1EVM
hello
We are designing a power distributor using TPS48111-Q1.
We are currently using multiple TPS48111-Q1 and checking the current value through each Imon pin.
question
- Is there a case where the Imon output value is output significantly differently in the same circuit? (There are cases where the Imon output value is output differently even on the same PCB.)
- If the output is different, is there a solution?
