BQ25638: BQ25638 Charging query
Part Number: BQ25638
Other Parts Discussed in Thread: BQ27Z746,
Hi
The customer design with BQ25638, when they were charging 10-100mA at different voltage of 3.0V, 3.6V, and 4.1V, we found that the voltage of 4.1V needs to reach 40mA to charge the battery.
The 10-30mA VBUS input has a set current value input, but the battery terminal does not. current value. What is the reason for this phenomenon?
ICHG configures 3200mA, 3.0V and enters fast charging to 3.5V. The fast charging current is 3.2A. When it reaches 3.5V, the fast charging current will jump to about 3.4A.
Waiting for your reply.
Star
  • Hi Star,
    We will check and get back to you.
    Ning.
  • Hi Star,
    We need additional information to be sure of the causes of these behaviors:
    For your first question, what are VREG, VRECHG, ITERM, and EN_TERM set to?  And what does the CHG_STAT register state?
    For your second question:
    • What VIN voltage and current is connected?
    • What is VSYSMIN set to?
    • What does CHG_STAT state?
    • Are VSYS_STAT, VINDPM_STAT, or IINDPM_STAT set to 1?
    • What method is used and what accuracy do you estimate for your fast charge measurement?
    Thank you!
    Katherine Huckabay
  • Hi TI team,
    A:VREG=4.2V,VRECHG=4.0V(VRECHG bit  set to 1),EN_TERM set to 1.The CHG_STAT is Fast Charge (CC).
    • What VIN voltage and current is connected?  ->5V 3A DC POWER
    • What is VSYSMIN set to?  ->VSYSMIN set to 3.52V
    • What does CHG_STAT state? ->  Fast Charge (CC)
    • Are VSYS_STAT, VINDPM_STAT, or IINDPM_STAT set to 1? ->VSYS_STAT=Not in VSYSMIN regulation,VINDPM_STAT=Normal,
    • What method is used and what accuracy do you estimate for your fast charge measurement?->Charge the battery simulator with 5v/3a dc POWER, set the initial voltage of the simulator to 3.3V, then adjust the battery simulator voltage to 3.5V,The charging current should be 3.2A±3%
  • Hi Eajon,
    For your first question:
    We are working to replicate the behavior your team has observed and will have results by the end of tomorrow.  We have a few more questions:
    • Is VINDPM_STAT, VSYS_STAT, or IINDPM_STAT set to 1?
    • We are not sure if the bq27z746 has enough resolution at those low of currents.  Could you confirm the results through another method such as connecting a sense resistor and a multimeter?
    • The ICHG accuracy is +/- 5% and if the measurement accuracy is an additional +/- 3% then 3.4A is within spec.  The change is seen due to the battery voltage approaching VSYSMIN.  This will cause the BATFET to change from linear mode to PWM mode and may cause an increase or decrease in battery charge current.
    • Was this increase to 3.4A observed on one device or multiple devices?
    Thank you!
    Katherine Huckabay
  • Hi Katherine,
      VINDPM_STAT  set to 1,VSYS_STAT and IINDPM_STAT set to 0.
    ->We connected the bq25638EVM directly to the battery simulator, and the test results were the same.
    • Was this increase to 3.4A observed on one device or multiple devices? ->multiple devices.
    Thank you!
  • Hi Eajon,
    • We were able to replicate the results your team observed in our EVMs.  BQ25638 is a 100mA-5A charger and is not designed for reliable charging startup with those low of adapter currents when the battery voltage is close to the adapter voltage.
    • However, we observed if you begin charging at a lower battery voltage (<= 3.8V) with a 10mA-30mA adapter current limit and gradually increase the battery to 4.1V it will continue to charge at 4.1V.  This behavior will be similar to a non-lab implementation.
    • This behavior is within spec with the measurement method used.
    Thank you,
    Katherine Huckabay
  • Hi Katherine,
     Because our products need to support 10-30mA charging current.VINDPM set to 4.72-4.8V.10-30mA charge is ok at 4.1V,but I wonder if this will have a bad effect on the charging IC.
     Thank you!
  • Hi Eajon,
    This will not have a bad effect on the charging IC.
    Katherine Huckabay
