Part Number: LM3000
Other Parts Discussed in Thread: POWERSTAGE-DESIGNER,
The POWERSTAGE-DESIGNER is not showing in the start menu after install.
Gokul.
Part Number: LM3000
Gokul.
Hi Gokul,
I cannot replicate this issue on my end. However, if Powerstage Designer was installed at the default location then you should be able to access it by navigating to the following path: C:\Program Files\Power Stage Designer 5. The application can be run from the folder
Britton
Hi Jones,
Thanks for your reply.
There are only bin folder and uninstall files are present. No Launcher is present in the folder.
Gokul
Hi Gokul,
Please try uninstalling and reinstalling the software. I am able to install a fresh download from the web on my pc with no issues.
You can also manually select a different installation directory to see if that improves the issue.
Could there be a security restriction on your pc? Could the installation process have been interrupted?
Britton
Hi Britton,
I try to install in another location, but nothing changed.
There is no application file present. Only inside Bin Java and Javaw application are present.
There is no error while installing.
Currently Kaspersky Enterprise security is running in my PC.
Gokul.
Hello Gokul,
I checked internally on this issue. Since we can not recreate the issue on our side, it is difficult to offer a solution beyond general Windows installation tips. I suggest checking on the security restrictions and trying to install as administrator.
If you do have any device specific questions about the LM3000, I am happy to help. Alternatively, if you are open to evaluating one of our newer devices and you can provide your application requirements, then I am happy to suggest part alternatives that may offer a wider range of design tools. Let me know and I am happy to help!
Britton
Hi Britton,
Thanks for your help. I will check with the IT team for security restrictions and get back to you soon.
Gokul
