I want to change the default voltage of BUCK2 to 1.8V
May I ask how to burn EEPROM
I am consulting our experts on this matter. Could you let me know if this is for prototyping or for actual end product production?
regards,
Niko
thanks for the information. We have not supported/recommended customers programming/defining their own EEPROMs. If you would need a custom EEPROM for your application you should contact your local TI sales/marketing team to advice you more on the process.
regards,
Niko
the BUCK2 can be set to 1.8V with the EVM GUI but I understand you only have the IC so this GUI will not work with your prototype board. The BUCK output depends on the OPN of the device. Could you use the TPS65313-EVM to evaluate the functionality?
regards,
Niko
did you check here. At least it shows the request button so they should be available. If they are not this should prompt our team to make more. You can't use SPI to reprogram the EEPROM since we don't support customer programming this device. You can change some registers with SPI when device is powered but these will be erased at loss of power.
regards,
Niko
I have contacted our team and will get back to you early next week.
regards,
Niko
