LM34927: UVLO resistor limit and shutdown/standby mode comparison
Part Number: LM34927
Hi Team,
I have 2 questions about LM34927, could you help me?
1. Is VCC regulator enable or disable the only different between shutdown mode and standby mode?
2. Is RUV2 & RUV1 have any resistance limit? And what's the resistance range recommended?
Thanks.
Roy
  • Hi  Roy,
    Thank you for posting.
    1. You are correct.  Between Shutdown and Standby, the VCC regulator is enabled to establish the logics, but the circuit holds off.
    2. Please refer to the datasheet section 8.2.1.2.12.  The two resistors are limited by equations (22) and (23).
    Hope this clarifies.
    Youhao
