TPS2595: TPS259573
Part Number: TPS2595
Hi team,
can you please provide the correct pSpice model for TPS259573 device. I checked in the website it is shown differently behaviour and it pspice is written for UVLO instead on OVLO.
where as datasheet shows as below,
Suresh R.
  • Hi Suresh,
    Yes, you are correct. Thank you for pointing it out. We will correct this and release new model with fixed model.
    Which pspice version are you using, is it Pspice for TI or Cadence Pspice capture cis? Can you also tell me how urgent it is?
    Arush
  • Hi Arush,
    I am working using Cadence Pspcie capture CIS 17.4.  I need it urgently to confirm and finalize the design.
    Suresh R.
  • Hi Suresh,
    We will work on the changes and release the fixes soon. You can use EVM for the prototyping and we can also verify your efuse schematic for you. I will inform you once I fix this issue but please expect some time delay. I will share the files directly with you.
    Once again thank you for bringing our attention to this issue.
    Arush
