Other Parts Discussed in Thread: TPS62A06
We found TPS62A06 abnormal star up before EN<1.2V, is it normal?
Any condition may cause Vout early rise up?
Thanks!
Jeff
Hi Jeff,
Yes, this is how it should work. You must drive EN above 1.2V to ensure that EN is high. But normally, it will be high below 1.2V.
This app note explains this topic in detail: https://www.ti.com/lit/an/slyt730/slyt730.pdf
Chris
No, this is not specified and can vary greatly based on the device or temperature, etc.
They should not rely on non-specified parameters to tune their timing. They need to make sure their system works with the specified timings. Can I help with that?
Chris
Hi Jeff,
The lowest logic high voltage, per the D/S, is 0.4V.
I can discuss your specific case via email.
Chris
