Hi
I'm planning on to use the LMR43620MSC3RPERQ1 and wanted to confirm in order to make the converter to work in FPWM mode always (VMode > VMode_H), is it okay to tie the MODE/SYNC pin directly to the VCC pin ?
The datasheet does mentions that VCC could be used for the logic supply of PG and should not be connected to any external loads. It would mean a lot if you can confirm on this.
Thanks a lot for your help !!
Vineet Anurag
