Hi, Support Team
We will use TPS2051, schematic as below chart. have any concern?
if any suggestion, Please advise me.
Lawrence
Hi, Support Team
Lawrence
Lawrence,
The only comment that I have is that you can select the TPS2041DR instead of the TPS2051DR and remove the PMOS inverter to reduce BOM.
Chuck
Hi, Chuck
As present, we have usage pressure of TPS2051DR inventory. At this stage, we will use TPS2051DR to consume the inventory.
Lawrence
Lawrence,
There is no issue with using the TPS2051DR, it just requires the inversion circuit that you have. The other option was a cost savings..
Your circuit will work correctly as draw.
Chuck
