Part Number: LM62440-Q1
Hi team,
Could you advise if there is a mandatory requirement for minimum RFBT value of LM62440-Q1?
it is described in the datasheet below, but I would like to use below 10kohm.
"Usually RFBT is between 10 kΩ and 1 MΩ."
This device automatically select Fixed voltage or adjustable voltage at start up, so I concern if selecting <10kohm causes any issue selecting adjustable output at startup.
regards,
