Does RT of this device have a limitation in the minimum value?
If RT = 8k ohm, What is the switching frequency?
Best Regards, Taki
Best Regards, Taki
Hello Taki,
Suggest staying within recommended frequency setting range with a max Frequency setting of 2.2MHz.
David.
Hi David,
I understood.
I want to know the device behavior if RT is lower than 9.52k ohm.
Best Regards, Taki
Hello Taki,
Should be fine to go over 2.2MHz. behavior will be normal RT=8k.
Hope this helps.
David.
Thank you for your quick response.
I expect the switching frequency should be saturated at individual maximum frequency at 8k ohm.
Do you have any number for the maximum frequency? Should it be 2.7MHz as shown in below?
Best Regards, Taki
