Other Parts Discussed in Thread: TPS7B84-Q1
Hello, Experts,
We have a question about the back PAD soldering joint area; Do we have a recommended joint area ratio excluding void?
Masaru
Hello, Experts,
Masaru
Hi Masaru-san,
I am not familiar with the term you are using. Could you provide an illustration highlighting the specific geometry you are interested in knowing?
The solder stencil is provided in the datasheet. Does this cover your question?
Hello, Marshall,
Please refer to the below diagram for where the customer is talking about:
For the green area i.e., PAD area, what is the recommended solder joint rate? For example, IPC-A-610 states that it should be >75% (=acceptable void rate <25%.)
Masaru
Similar threads that I found for a different device:
For devices with PowerPAD like TPS7B84-Q1, the minimum requirement is 50%:
https://e2e.ti.com/support/power-management-group/power-management/f/power-management-forum/1256499/tps7b84-q1-minimum-recommended-thermal-pad-soldering-joint-area-for-tps7b84-q1?tisearch=e2e-sitesearch&keymatch=Solder%252520joint%252520ratio#
Our customer considers WSON package (LM63615DQDRRRQ1) so would like to know in this case what would be the recommended soldering joint area rate is.
Hi Masaru,
Are you ultimately trying to know the acceptable void rate to determine how thermals would be impacted? I don't think we would have that data just like the other product line.
Our stencil guidance I gave you previously and here is guidance on the reflow profile for assembly accuracy.
