Part Number: CSD17577Q5A
Other Parts Discussed in Thread: CSD17579Q5A
I am currently using the CSD17577Q5A in a synchronous buck battery charger
Specifications are below:
Vin = 19.7V
Vout = 13.8V
Iout = 10A
Fsw = 350kHz
PCB Stackup:
6 layers, Surface finish HASL-Lead Free
L1 2oz = SIG/PWR/GND
L2 1oz = GND
L3 1 oz = SIG/PWR/GND
L4 1oz = PWR
L5 1oz = GND
L6 2oz = SIG/PWR/GND
Currently with our first prototype everything works fine, other than the concern I have for the temperature rise of the HS mosfet in room temperature
At full load of 10A and 13.11V output the HS mosfet gets up to 72.3C (temperature measurement was made on a thermal imager on the top side of the mosfet case) . Based on the SYNC mosfet calculator sheet you have the estimated total power loss of the mosfet is about 1.3W
Currently there is copper on all layers(except solid GND layers underneath this mosfet with thermal vias
Based on this information the estimated Junction thermal ambient resistance is about 40.4 C/W (assuming 2.8 C/W junction to case temperature)
Couple of questions I had regarding this was
1) for this mosfet have you been able to reduce the Junction to ambient thermal resistance by much more than this in a practical application(assuming my estimated calculation is correct)?
2) Do you see this as a concern that the mosfet is getting this hot during these conditions? Our product will be in an enclosure so the air within the enclosure will rise to about 45C
Any suggestion/concerns that you may have will be greatly appreciated
