BQ27010: refresh
Part Number: BQ27010
BQ27010DRKR encountered the following problem:
5315.原理图.PDF
The attachment is the schematic diagram of this battery;  1.  the electricity meter will not refresh (the chip crashes) (that is, it will not scroll in the Value column).  Problem: It is normal when the semi-finished battery is tested (the column of Value rolls normally), and the ammeter will not refresh (do not roll) after the battery is ultrasonically sealed;  This problem cannot be solved by charging and discharging;  Only when the battery is disassembled, powered off and powered on again will it refresh normally.  How to avoid this problem and how to solve it without disassembling the battery after it appears?
