Because of the holidays, TI E2E™ design support forum responses will be delayed from Dec. 25 through Jan. 2. Thank you for your patience.
LMR14050-Q1: Enable/Disable
Part Number: LMR14050-Q1
Hello, can I use this circuit to enable/disable the LMR14050-Q1 through its enable pin? Basically when RESET_SIG is low, Q3 turns off. Do I have to put a pull-down resistor (R6 here) between the enable pin and GND?
