LM74930-Q1: Negative transient voltage and reverse current capability
Part Number: LM74930-Q1
 hi experts,
If I deactivate reverse current blocking using the mode pin, will the Transistor Q2 stay on while there is a surge at the input?
In the first picture an empty DC-Link is assumed and in the second picture the DC-Link Cap is at 54,8V.
It is the negative surge voltage (-126,3 V clamped with TVS at VIN), which gives me a headache.
If Q2 stays on, providing reverse current capability, the DC-Link would be discharged, and this is fine for my application.
If Q2 switches off, the maximum C-A voltage (85V) would be violated.
Unfortunately, I can’t use any lower voltage TVS in negative direction at VIN, because I need the circuit to withstand permanent reverse voltage of -54,8 V.
best regards,
Artur
  • Hi Artur
    Welcome to E2E!
    What is the application? why are you expecting negative voltages in the range of -126,3 V ? and how long this interval lasts ?
    If VS is +ve, then Q2 remains in ON state when reverse current blocking is disabled. However, your supply VIN gets shorted through Q1 and Q2 - right ?
    BR,
    Rakesh
  • Hi Rakesh,
    the application is an electromotoric brake actuator for railway. The circuit needs to survive +/-1kV 42 Ohm surge pulse with typical 8/20µs current waveform. That's why i have bidirectional TVS with 126,3 V maximum clamping voltage at the input so far. Of course, the additional Zener clamp with 60 V at VIN will also be used.
    What do you mean with +ve? Yes, the VIN supply would be shorted through Q1 and Q2.
    The circuit will be supplied with nominal 48 V and max. +54,8 V, but needs to survive reverse voltage of -54,8 V permanently.
    Assume an empty DC-Link (left picture) and a -1kV surge pulse, the clamping voltage of -126,3 V would be too high, right?
    regards,
    Artur
  • thanks for the details Artur.
    1kV 42 Ohm surge means around 24A of surge current. So, a 60V bi-directional TVS diode such as SMC30J58A/CA https://www.st.com/resource/en/datasheet/smc30j10a.pdf helps to clamps to very low voltage than 126.3V
    Vcl = Vbr(max) + surge current * Rd(max)
    =71.4 + 24*0.153 = 75V.
    Now the voltage across Q2 FET will be +54,8 V +75V = 130V.
    You need to select Q2 with Vds rating higher than 130V
    To support higher voltage between A and C pins, we can use a depletion NFET like BSS126 for Q3 which disconnects C pin from VOUT when A becomes negative than C.
    Please get an EVM and try out with these changes and let me know.
    Rakesh
  • hello Rakesh,
    i didn't see a differential resistance in TVS datasheets before and always calcualted with max. clamping voltage, so thank you for the example!
    i recently also found an intersting TVS with very low clmaping voltage:
    The depletion FET is a great idea! i will try and test the circuit as soon as possible and will share my results with you.
    Artur
  • yes Artur.
    This TVS diode looks better.
    Please evaluate and let us know.
    Rakesh
