Other Parts Discussed in Thread: TPS3435
Hello forum,
I wanted to ask about the TPS3435 watchdog, specifically the TPS3435AFACADDFRQ1 version. Could you please indicate how it can be disabled? I'm not entirely clear on this.
Thank you
Hello forum,
Thank you
Hi Manuel,
The TPS3435AFACADDFRQ1 (A pinout option) can be disabled by connection the CWD pin to either ground or a capacitance value greater than recommended (>>1uF).
This information can be found under section 8.3.1.2 Watchdog Enable Disable Operation:
Joshua
