Other Parts Discussed in Thread: CSD
Hello Team TI,
I'd like to inquire about a difference in voltage drop observed between two MOSFET back to back Mosfet with common drain configurations in a circuit using the LM74800QDRRRQ1 Driver IC. Simmilar to the below configuration.
In the first configuration, employing a PSMN series NXP MOSFET, I haven't measured any noticeable voltage drop.
On the other hand, when using a TI CSD18540Q5BT MOSFET in the identical schematic, I've observed a voltage drop of around 0.6 to 0.7 VDC across the MOSFET at currents up to 2A.
Can you help me understand why there's a difference in voltage drop between these two MOSFETs in the same circuit?
Murthy
