Other Parts Discussed in Thread: TPS25750, BQ25756E, TUSB4020BI, BQ25756, TPS25751
My client wishes to have a USB Hub for charging (USB PD 3.0) as well as communication to a down stream device via D- and D+ pins. For example a laptop would be plugged in and would be able to charge at 20V 5A but would also be able to communicate to a Hard drive and flash stick that is also plugged in. Only D- D+ , CC1/2 and Power connection is available.
Searching I think I found the needed IC for this project TPS65982 however it seems to be phased out...
My question is: Is there an IC that can replace this with similar functions? Is there perhaps a 2 or 3 IC solution that could implement this?
