Other Parts Discussed in Thread: BQ76952,
How to calculate Rcb resistor value for 500mA cell balancing current with External MOSFETs.
Please explain .
Hi Jaya,
I recommend reading Section 2 of the Cell Balancing application note for the BQ76952: https://www.ti.com/lit/an/sluaa81a/sluaa81a.pdf.
The device is different, but the concepts are the same. The only difference will be the internal FET resistance and the internal current limits. The internal resistance is ~12 ohms, and the abs max internal current is 50mA for the BQ77915.
Max Verboncoeur
Hi Max,
Thanks for your response. This link https://www.ti.com/lit/an/sluaa81a/sluaa81a.pdf not opening. please share correct link.
Jaya Prasad
Hi Jaya,
Apologies, for some reason the period got added to the end of the link. https://www.ti.com/lit/an/sluaa81a/sluaa81a.pdf
Max Verboncoeur
