Because of the Thanksgiving holiday in the U.S., TI E2E™ design support forum responses may be delayed from November 25 through December 2. Thank you for your patience.
TPS65131-Q1: Schematic/application review
Part Number: TPS65131-Q1
Other Parts Discussed in Thread: OPA1612,
Hi there,
I'm after a split rail supply to power 8 x OPA1612 op amps in a high quality preamplifier. I'm limited to using a single DC supply to the board. I have put together a schematic using the TPS65131-Q1 IC. It is designed for +/-15V which is then further filtered and rectified to +/-12V to give clean power to the op amps. Here is the schematic:
Is this the best way to achieve my end result (clean power for the op amps), or am I missing a trick?
Any tips appreciated.
Many thanks!
