Does the TPS22946 have a built-in discharge circuit that bleeds the output when the load switch is disabled (ON goes LOW)? If not, can you suggest a different ultralow power load switch that has a discharge function or can you suggest a circuit to add on the TPS22946 VOUT to discharge VOUT?
This load switch is controlling power in a battery application so I don't want to bleed the battery while the switch is turned ON.
