Hi Team,
Customer report the vout waveform is abnormal when pull the enable low. Pls check the waveform and schematic below. As double check with customer the test method is good. Do you have any comments for this case?
Hailiang
Hello Hailiang,
Thank you for your question.
Please allow me 2-3 business days to review your request.
Thank you,
Hannah
To me, this looks like a capacitor decay on the output. Could you please send me another scope shot zoomed out. I want to see if the output settles eventually? What is the customer measuring at their output after the decay?
Hannah
Hi Hannah,
Vout will eventually stabilize to 0V. Please refer to the waveform below.
In addition, share the waveform with Bias signal as follows.
Not every device has this abnormal waveform. But the problem appears in multiple rails(1.2V to 0.9V *4, 1.8V to 1.5V rail *1). Is this issue known? Can you please suggest how to debug?
Hailiang
Hello Hailiang,
Please allow me one day to get a response to you based on this inquiry.
Hannah
