Part Number: UCC28782
Other Parts Discussed in Thread: UCC24612, UCC28780, LMG3616, LMG3622
I asked a question in the thread below about the secondary side synchronous rectification controller used with UCC28782 and got an answer.
I would like to ask you a similar question as I would also like to get an opinion from the UCC28782 perspective.
I am using Infineon's IR11662S as the secondary side synchronous rectification controller in the UCC28782 circuit.
However, when evaluating the manufactured board, abnormal oscillation-like behavior was observed in the switching waveform.
Therefore, I am considering using UCC24612 instead of IR11662S.
(Question 1)
IR11662S has similar characteristics to UCC24612-2, but is it better to use UCC24612-1?
(Question 2)
UCC28780 recommends the use of UCC24612, but UCC28782 does not seem to recommend its use.
The EVM of UCC28782 also uses MPS's MP6908.
Please let me know if there is a reason.
(Question 3)
Does the selection of secondary-side synchronous rectification controller affect the switching behavior of the UCC28782?
For reference, I have attached the UCC28782 calculation tool that I set up.
The main FET of UCC28782 is LMG3622, and the one for active clamp is LMG3616.
