The TI E2E™ design support forums will undergo maintenance from July 11 to July 13. If you need design support during this time, open a new support request with our customer support center.
LP2951-N: undervoltage range : 5% define?
Part Number: LP2951-N
Want to use LP5951-N's under voltage function
refer to the datasheet below
If use 3.3V version, then the under voltage minimum is 3.254V *95% or 3.3V*95%?
    The ERROR functionality is not specified in a way that allows for a minimum calculation for the trip voltage. From the EC table specs, the maximum trip voltage for VOUT falling is 1 - 25mV/1.235V = (1 - 2%)*VOUT = 98%*VOUT, and the typical trip voltage is 95%*VOUT. Since there is not a maximum value specified for the upper threshold voltage, the minimum trip voltage cannot be calculated. Unfortunately, we have limited documentation for these old legacy devices so we can't provide characterization data for this.
    Nick
