LM25149-Q1: Calculator output capacitor calculation error and need double-check
Part Number: LM25149-Q1
Other Parts Discussed in Thread: LM25149
Hi team,
My customer used our LM25149, and find the output result of our official calculator cannot match with the manual calculation result.
Could you please help double-check it? The calculator's result is 2.2uF, and the manual result is 12uF.
The mission profile is given following:
The manual result is:
The calculator's result is:
Could you please help provide the result and process from your side?
Thanks a lot!
Matt.
  • Hello Matt,
    The minimum output capacitance is based on the below equation:
    Are you using similar equation in your manual result?
    I plugged it into my manual result and I got the below.
    The nearest value is a 2.2uF capacitor, however this is not the minimum capacitor needed for stability so we don't usually design Cout for only ripple.
    Jimmy
