I've used LM27761 to generate -5V from a typical Li-Po battery (3.7v). However, I can just obtain -3.47V at the output of LM27761. I share my circuit below;
As shown in the application information below from the datasheet, using a positive voltage in the range of 2.7 V to 5.5 V to a negative output voltage configurable with external gain setting resistors, I tried to get -5V.
However, it does not work even though I use the calculation in the datasheet to determine the resistor values and follow the typical application design;
I wonder whether to generate -5V from a typical Li-Po battery by using the component? Did I miss something?
Thank you in advance for your help
