Hi team,
May I ask about the max and min value of the switching frequency set by the resistor? We are seeing a 45kHz error on the fs.
Han
Hi team,
Han
Hi Han,
What FSW setting are you selecting? There is some tolerance to the setting and to the resistor. That said, the fsw settings are not discrete so you can adjust the resistor slightly to achieve your desired setting.
Britton
Hi Britton,
We found that under heavy and light load, the switching frequency has a change of 2kHz, is this normal? Could you explain the reason? My understanding is that they work in fixed frequency mode instead of COT mode.
BR//
Songlin Cai
Hi Cai,
Are you seeing the frequency shift down by 2kHz at high loads? This is likely due to higher IC temperature and is not unexpected. I do not have distribution data that I can share externally
Britton
