The TI E2E™ design support forums will undergo maintenance from July 11 to July 13. If you need design support during this time, open a new support request with our customer support center.
UCC21710-Q1: Impedance of OC pin
Part Number: UCC21710-Q1
Other Parts Discussed in Thread: UCC21710
I'm using UCC21710 and would like to utilize OC pin for overcurrent protection.
Since I have a current sensor on the low voltage side, I am using a digital isolator to transmit overcurrent signal to OC pin. In this case, can I connect the output of the digital isolator to OC pin directly?
As I read "8.3.7 Overcurrent and Short Circuit Protection" of the data sheet, I found that the OC pin is high-Z only when the output is high. Thus, I'm wondering if I need resister between the digital isolator and OC pin to avoid large current flows into OC pin.
If I don't need the current limiting resister, what would happen when the output is low and OC pin is pulled to high?
Thank you.
Mamoru
