The TI E2E™ design support forums will undergo maintenance from July 11 to July 13. If you need design support during this time, open a new support request with our customer support center.
LMR33630-Q1: Some questions from the customer
Part Number: LMR33630-Q1
Hi WVB Team,
May you have a good day!
My customer has some questions, could you please help to answer, thanks in advance!
  1. They wonder the forward voltage of LMR33630CQRNXRQ1 high side switch parasitic diode ;
  2. They wonder the Gate Resistors and Shunt Resistor value of LMR33630CQRNXRQ1 MOSFET;
  3. Does LMR33630CQRNXRQ1 have any sort of dynamic ESD Circuity on VIN pin or other pin? They wonder the ESD performance for each PIN;
Jack
  • Hello Jack,
    1/2. These information pertains to the internal device and is information generally not provided to customer. From an application point of view, what is customer going to use this information for? For efficiency and thermals, WEBENCH Designer tool can help with your simulation needs.
    3. The datasheet shows the ESD rating of the device which is applicable to the pins and package as a whole.
